Firmware Release Notes
The Release Note Page documents the ongoing development of the Centro Business Router. It provides an overview of all technical and functional modifications implemented as part of software updates.
Entries are classified by their origin and impact:
- New Features: Documentation of newly added functions.
- System Optimizations: Adjustments to existing functions to increase stability or efficiency.
- Bug Fixes: Documentation of corrected software anomalies.
- Removed Features: Features that have been removed from the router.
Centro Business Firmware Newsletterβ
We will inform you early via email about upcoming firmware updates and important technical news regarding the Centro Business Firmware.
Sign up using the form to be added to the mailing list.
Register now
Firmware files no longer publicly availableβ
For security reasons, Swisscom no longer makes the firmware files publicly available for download.
Firmware updates are distributed automatically via Device Management. A manual update is only possible in the router portal via the update button β and only when a newer version has already been released for the router. The procedure is described under Manual firmware update procedures.
SSH access disabled (all firmware versions)β
As a security measure against known vulnerabilities, SSH access (shell access) over the LAN has been disabled on the Centro Business 2.0 and Centro Business 3.0. This applies to all devices regardless of the installed firmware version.
Centro Business 3.0β
Pre-announcement Router Firmware 10.06.02 (B42) - November/December 2026
Publication/Introduction: coming soon (November/December 2026)
Firmware downgrade not recommendedβ
Swisscom recommends not downgrading to an older firmware. Earlier versions contain significant security vulnerabilities that were closed with this firmware version.
Fixed Bugsβ
VoIP β UPDATE method (SIP-TA)β
With registered end devices (e.g. DX800), a call could drop after about 3 minutes. The cause was that the Centro Business 3.0 did not correctly handle the SIP UPDATE method during the session refresh and did not forward the end device's response to the telephony platform. A generic solution was implemented. (CB-11690)
VoIP β as-feature-event SUBSCRIBEβ
For the customer, this meant that the settings in the customer center were no longer in sync with the settings on the router or IP phone. The cause was that the re-sending of the SIP SUBSCRIBE for as-feature-event occurred too late or at incorrect intervals. The re-SUBSCRIBE is now correctly sent after 90% of the validity period specified by the platform, so the settings stay in sync. (CB-12132)
VoIP β DTMF with intercom systemsβ
With Passotel intercom systems, triggering the door opener failed (error message "Invalid SSRC or Payload"). The voice connection worked, but the DTMF tones for opening the door were discarded. The error in processing the RTP stream for DTMF events was fixed. (CB-12306)
VoIP β lost registration after IMS maintenanceβ
After certain maintenance activities on the telephony platform, individual devices could fail to re-register automatically. Telephony was then limited (incoming calls did not work, while outgoing calls remained possible), even though the VoIP LED and the router portal incorrectly showed the lines as registered. The re-registration and the correct status display were improved. (CB-12500)
Port forwarding via static routesβ
After migrating from CB 2.0 to CB 3.0, port forwardings to targets reachable via a static route no longer worked (rule status "Error"). Forwarding to such targets was corrected and now behaves as it did on the CB 2.0. (CB-11879)
Firewall rules after backup & restoreβ
When restoring a configuration via backup & restore, the custom DMZ firewall rules were not applied. The rules are now correctly applied. (CB-11924)
Securityβ
Several critical security vulnerabilities were closed.
New Featuresβ
Software acceleration (SW-Accel) for VPN trafficβ
The Centro Business 3.0 now has a software accelerator. This allows VPN traffic terminated behind the Centro Business (e.g. on a firewall/appliance in the DMZ) to be accelerated, significantly increasing throughput performance. (CB-12181)
DynDNS β token-based authenticationβ
DynDNS now supports token-based authentication with the preconfigured providers as well as β where possible β with custom update URLs. (CB-11762)
Password strength assistanceβ
The indicator that rates password strength (from weak to strong) was extended to further areas: now also for the router password and for the pre-shared key for P2P VPN. (CB-11912, CB-11920)
DHCPv6 β new DUID typesβ
The Centro Business 3.0 now additionally supports DHCPv6 DUID type 4. This ensures IPv6 compatibility with modern networks. (CB-11921, CB-12199)
Removed Featuresβ
SSH access for techadmin removedβ
For security reasons, SSH access (shell access) via remote access was disabled for the techadmin user. This account is now managed exclusively via the WebUI. (CB-11891)
SSH disabled in generalβ
As a general security measure, SSH access (shell access) on the Centro Business 3.0 was fully disabled. (CB-11891)
VoIP β T.38 disabled by defaultβ
The T.38 fax mode is now disabled by default in the factory state. (CB-12353)
Known Bugsβ
The following points are known and will be addressed in a future firmware:
techadmin β no redirect to the login pageβ
If techadmin is activated in the router portal while logged in as superadmin, superadmin is automatically deactivated and logged out. However, the expected automatic redirect to the login page does not happen, and the router is then no longer reachable via the WAN IP. (CB-12508)
Deleting a firewall rule without confirmationβ
When deleting a firewall rule, no confirmation prompt currently appears. The rule is removed immediately, which means it can be deleted by mistake. (CB-11706)
DMZ firewall migration OFF β Customβ
When the firewall is switched from "OFF" to "Custom", the router only allows outgoing traffic (DMZ β WAN). Incoming traffic (WAN β DMZ) is blocked β as a result, e.g. VPN connections to a firewall in the DMZ can no longer be established. Workaround: manually create an additional rule for the reverse direction (WAN β DMZ). (CB-12401)
Internet Backup β wrong access technologyβ
In the Internet Backup GUI, "GSM (2G)" is incorrectly shown as the default access technology, even though the 2G service has been switched off. (CB-12505)
The codes shown in brackets (e.g. CB-12505) are internal Swisscom reference IDs and serve internal purposes only, such as traceability.
Router Firmware 10.04.14 (B41++) β July 2026
Release Date: July 2026
This firmware is currently only being deployed on the Centro Business 3.0 in combination with the Alcatel/TCL Internet Backup Stick (black dongle).
Fixed Issuesβ
Mobile Failover with Alcatel/TCL USB Dongles (Published via ComHub)β
After repeated WAN failover cycles, the Alcatel/TCL USB dongle remained stuck in the "Initialization / Waiting for Authentication" status. As a result, the router failed to establish a mobile backup internet connection. This issue has been resolved with this release.
Router Firmware 10.04.12 (B41+) - March 2026
Announcementβ
Action Required for PPP-Passthroughβ
In the router portal, a notification has been added regarding the future decommissioning of PPP-Passthrough. Customers are informed that switching to one of the recommended alternative solutions such as DMZ or
IP-Passthrough is mandatory.
New Featuresβ
New Telephony Platformβ
This firmware ensures that technical migrations to the new telephony platform in the beem Office / beem Office environment are enabled. (No customer impact)
Optimizations to LAN & DMZ Firewallβ
The firewall on the Centro Business 3.0 has been completely redesigned. The goal of these adjustments is to prevent unprotected router configurations while further increasing the security and stability of the Centro Business 3.0.
The firewall now only offers the operating modes Strict (default) or Custom.
The previous OFF mode is now intentionally only available as a Custom configuration to be performed by users (expert function).
For each "firewall rule", the protocol can now be defined between Any or ICMP, GRE, AH, ESP.
Important:β
A firmware update or a backup & restore (CB 2.0 β CB 3.0 or CB 3.0 β CB 3.0) does not change the existing firewall behavior or the configured firewall rules. However, with the B41 release (version 10.04.07.0006 and later), previous operating modes such as "Balanced", "OFF", or "CUSTOM" are automatically assigned to the "Custom" mode. Further details can be found under "CB3.0 New Firewall Behavior". Additionally, the display of firewall settings has been redesigned and optimized.
Increased Cybersecurity Requirements via EU Regulation "RED-DA"β
The regulation in force since 01.08.2025 has led to the following measures:
- Increased password complexity requirements for
- WLAN (16 instead of 10 characters)
- VPN (12 instead of 10 characters)
- Router portal "admin" (12 instead of 10 characters)
- Removal of the "Central USB Storage Device" function
- Implementation of further security improvements
β β The user will only be prompted to change the password length in the router portal if the previous configuration is modified. This can be canceled, but it is not recommended.
For illustration: Theoretical duration of a brute-force attack to crack the password: - 8 characters with 4 types = 30 min
- 10 characters with 4 types = 5 months
- 16 characters with 4 types = 92 billion years
Assistance for Password Strengthβ
To improve general security, a display has been integrated into the password fields that evaluates the complexity of the chosen password (from weak to strong).
Use a password that meets at least the following criteria:β
- min. 12 characters (for WLAN min. 16 characters)
- at least one uppercase letter
- at least one lowercase letter
- at least one number
- at least one special character
Removed Featuresβ
Removal of the "Central USB Storage Device" functionβ
For security and compatibility reasons, this obsolete function is being removed from the router portal.
Details can be found under Central USB Storage Device
Fixed Bugsβ
Firewall ## Firewall & Port Configuration: Port Configuration:β
An issue was fixed where port 443 was incorrectly blocked by the firewall after a firmware update. Manual adjustment of firewall rules to restore functionality is no longer required after this patch.
System Identification:β
A bug was corrected that caused the router's serial number to be incorrectly reset to the default value "SN1" under certain conditions. Correct hardware identification is now permanently guaranteed.
Port Forwarding:β
Occasionally, port forwardings did not work when the router switched to Internet Backup mode. (CB-11016)
TV Host:β
In certain cases, a freeze of the image occurred after changing channels. (CB-11291)
Security:β
Various security vulnerabilities have been closed.
Router Firmware 10.04.10 (B41) - January 2026
Important Informationβ
This version is replaced by firmware 10.04.12. All updates from version 10.04.10 are included in the 10.04.12 release notes.
Router Firmware 10.04.04 (B40)
Publication/Introduction: May 2025
Preparationβ
New Telephony Platform**β
The firmware ensures that test phases and technical migrations with a new telephony platform in the InONE SME environment are made possible. (No customer impact)
New Functionsβ
beemNetβ
With the introduction of the new security offering at Swisscom B2B, the router portal indicates that DynDNS and Port Forwarding cannot be used, or can only be used after prior definition of corresponding security rules, when beemNet is activated, depending on the selected Security Edition. Further information can be found at: www.swisscom.ch/beem
Switching the Entire Mesh WLAN On and Offβ
(only in combination with Business WLAN Box) The firmware now supports central control of the Mesh WLAN via the WLAN button on the Centro Business 3.0. This allows the visible WLAN in the entire Mesh network (incl. Business WLAN Box) to be switched off or back on.
DynDNSβ
The option for the custom DynDNS URL now also supports HTTPS. (CB-10790)
Fixed Bugsβ
GRE Tunnelβ
GRE Tunnel: When a GRE tunnel was used with a security gateway/firewall behind the Centro Business 3.0, this traffic showed poor performance. (CB-9699)
IPSec VPNβ
When an IPSec VPN tunnel was used with a security gateway/firewall behind the Centro Business 3.0, this traffic showed poor performance (approx. 500MB). (CB-10403)
QoSβ
With XGS-PON, an error in QoS handling was resolved. (CB-9712)
Business WLAN Box:β
Various improvements in the wizard and Mesh technology. (CB-9624, CB-9978, CB-10000, CB-10319, CB-10418)
Older Firmware Versions
Centro Business 2.0β
Router Firmware 9.52.26 (B20) - October 2026
Publication/Introduction: October 2026
Replaces firmware 9.52.24β
This firmware replaces version 9.52.24. In 9.52.24, the PPPoE connection no longer worked when PPP-Passthrough was enabled (see "Fixed Bugs"). Version 9.52.26 fixes this issue and contains all other changes from 9.52.24.
Fixed Bugsβ
PPP-Passthrough after firmware updateβ
After updating to firmware 9.52.24, the PPPoE connection no longer worked on routers with PPP-Passthrough enabled β the internet was no longer reachable, while the management connection (DHCP) kept working. Only devices with PPP-Passthrough enabled were affected. The issue has been fixed; PPP-Passthrough works again as before after the update. (CB-12543)
With registered end devices, a call could drop after a short time because the Centro Business 2.0 did not correctly handle the SIP UPDATE method during the session refresh. A generic solution was implemented. (CB-11689)
With Passotel intercom systems, triggering the door opener failed (error message "Invalid SSRC or Payload"). The voice connection worked, but the DTMF tones for opening the door were discarded. The error in processing the RTP stream for DTMF events was fixed. (CB-12136)
After certain maintenance activities on the telephony platform, individual devices could fail to re-register automatically. Telephony was then limited (incoming calls did not work, while outgoing calls remained possible), even though the VoIP LED and the router portal incorrectly showed the lines as registered. The re-registration and the correct status display were improved. (CB-12507)
Securityβ
Several critical security vulnerabilities were closed. (CB-11971)
Removed Featuresβ
For security reasons, SSH access (shell access) for the techadmin user was removed. This account is now managed exclusively via the WebUI. (CB-11892)
WPS trigger via the hardware button disabledβ
For security reasons, WPS can no longer be started via the WLAN hardware button on the device. This prevents potential access by unauthorized persons who have physical access to the WLAN button. WPS can now only be triggered via the router portal (WebUI); the WLAN button is still used to turn the WLAN on and off. (CB-12535)
The codes shown in brackets (e.g. CB-12535) are internal Swisscom reference IDs and serve internal purposes only, such as traceability.
Router Firmware 9.52.22 (B19+) - July 2026
Publication/Introduction: July 2026
This firmware is currently only installed on Centro Business 2.0 in combination with the Alcatel/TCL Internet Backup Stick (black stick).
New Featuresβ
Increased Cybersecurity Requirements through EU Regulation "RED-DA"β
The regulation, which came into force on 01.08.2025, has led to the following measures:
- Router Portal "admin" (12 instead of 10 characters)
β β The user is only prompted in the router portal to change the password length when modifying existing configurations. This can be cancelled, but is not recommended.
- min. one uppercase letter
- min. one lowercase letter
- min. one number
- min. one special character
Fixed Bugsβ
After repeated WAN failover cycles, the Alcatel/TCL USB dongle remained stuck in the "Initialization / Waiting for Authentication" state β The router was unable to establish an internet connection via mobile. (CB-12144)
Router Firmware 9.52.20 (B19)
Publication/Introduction: November 2025 / Q1-2026
Announcement:β
Action required for PPP Passthroughβ
The router portal now draws attention to the future discontinuation of PPP Passthrough. Customers are informed that switching to one of the recommended alternative solutions such as DMZ or IP Passthrough is mandatory.
New Functionsβ
This firmware ensures that technical migrations to the new telephony platform in the InOne SME / beem Office environment are made possible. (No customer impact)
DynDNSβ
Assistance with Password Strengthβ
To improve general security, a display has been integrated into the password fields that evaluates the complexity of the selected password (from weak to strong).
- min. one number
Fixed Bugsβ
VoIPβ
In rare cases, the INVITE was not answered by the router, leading to call termination. (CB-11227)
TV Hostβ
In certain situations, an image freeze occurred after changing channels. (CB-11479)
Internet Backup: When WAN ETH failover was activated and the Internet Backup stick was subsequently plugged in, a faulty state occurred: Failover no longer worked and the WAN ETH failover option could not be deactivated. (CB-10969)
Securityβ
Various security gaps were closed.
Router Firmware 9.52.18 (B18)
Preparationβ
New Functionsβ
beemNetβ
Fixed Bugsβ
- Backup/Restore: Firewall rules are restored. (CB-10163)
- Missing notification when replacing the SFP module added. (CB-9145)
- DECT: Optimization of the display of missed calls on DECT handsets (CB-6280)
Router Firmware 9.52.14 (B17)
Publication/Introduction: November 2023
New Functionsβ
- Internet Backup: The firmware supports the replacement product for the USB failover Internet Backup stick (Alcatel IK41VE1).
Fixed Bugsβ
- WAN IP: In rare cases, the router does not obtain a WAN IP address after a restart. (CB-8145)
- ATA: When the Centro Business 2 switches to Internet Backup, incoming calls to the analog telephone interface do not work. (CB-8801)
- Backup & Restore: Certain settings are not saved in the backup file. (CB-8742)
- USB Internet Backup: On the local web portal, the timestamp for Internet Backup is incorrectly indicated in UTC instead of local time. (CB-8406)
- Change Web Portal Password: The local web portal password cannot be changed if the new password contains a "0". (CB-9133)
- LAN Port 1: When the DMZ option is deactivated, Swisscom TV on LAN Port 1 does not work. (CB-8925)
- Smart Business Connect Telephony: One channel per number via SIP-TA: The number of simultaneous calls (incoming or outgoing) was corrected to 1 active call per configured telephone number. (CB-8737)
- Security: Various security gaps were resolved. (CB-8448, CB-7551, CB-8414, CB-8556)
- General: Various stability problems resolved
FAQ - Firmware Release-Noteβ
Where can I see the current schedule during a firmware rollout phase??
Depending on the router model, Swisscom plans 1-2 rollouts per year. Routers are usually updated in tranches Tuesday through Thursday during the night (between 2:00 - 6:00) via "Device Management". This leads to a connection interruption of approx. 10 minutes. The Centro Business 2.0 / 3.0 Rollout Plan
is published accordingly.
Is something missing here? Give us your feedback!
Help us improve the CB-Guide. Let us know what content you are missing or how we can improve.
Send feedback
